Old August 10th, 2018, 10:26   #1
tdidieselbobny
tdidieselbobny's Avatar
Default Dieselgeek oil bypass....
Hi folks! I bought an '03 Jetta that had the Dieselgeek oil bypass filter installed(secondary). Being that it was installed at around 250k on engine I believe, is it worth it to keep it? Why I ask is that I'll be replacing valve cover in awhile due to leaks(already have new one) and the return port from DG filter is cobbled into the valve cover now w/ JBWeld it looks like,but doesn't leak, not sure If I'd be able to save the fitting when I do swap valve covers. Another question is the extra filter holds about a quart of oil-I changed it w/ last oil change, but supposed to last 20k-30k(maybe more). Do I have to remove filter and drain what I can and reinstall the used filter back on to get the most oil out of system so I don't add the dirty oil back into fresh oil? Seems to defeat purpose, and I sure as hell not going to spend anywhere from $30-$60 for another amsoil filter each change. I was thinking of just removing it and selling it, it's just a secondary car I'm using to not rack up miles on my '15 GSW as fast.....
97 Passat TDI-420,688 miles,totalled by 86yr.old lady-gone,but not forgotten-'15 Silk Blue Golf Sportwagen w/DSG, 24k miles....'16 Kubota BX1870 MMM/FEL, 100hrs!And now an '03 Jetta TDI 5spd w/ 423k,RC2,Sprint 520's,Dieselgeek short shifter and oil bypass, and a few other goodies....
tdidieselbobny is offline   Reply With Quote
Old August 10th, 2018, 11:29   #2
Ol'Rattler
Ol'Rattler's Avatar
Seriously, a solution looking for a problem. When you can disassemble a TDI engine at 400K miles and there is still evidence of cross hatching on the cylinder walls the stock oil filter and oil system must be doing something right.
I had an old Rambler that the oil filtration system from the factory that was of the bypass type. With those once the filter started getting dirty they would pretty much start to clog up. What they do is bypass pressure and volume away from componants the require full time lubrication.
Putting a bypass filter on a modern engine that already has 100% full oil filtration already is just plain absurd.For $180 for the setup and $41 each for the filters, the only thing the bypass filter is cleaning is your wallet.
Be strong! Don't become a member of the Amsoil cult. When Amsoil founder Albert J. Amatuzio "borrowed" synthetic oil technology from military aircraft in the 60's the benefits were a big deal, but nowadays all oil companies market synthetic oil.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old August 10th, 2018, 11:40   #3
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
Having the oil return entering via the valve cover just seems wrong.
1.9ZOOK is offline   Reply With Quote
Old August 10th, 2018, 11:52   #4
phaser
Fuel Economy: 51 MPG B-20
The Amsoil bypass filter filters down to 2 microns, where the stock filter comes nowhere close. And I change the bypass filter every 100k, and it still has good flow (EaBP100). Any sooner and it's a waste of money. And with the bypass filtering the entire sump every 10 minutes or so, what's not to like.
I once did a UOA at about 10k on the oil, immediately post filter just to see how well it was performing. Analysis came back showing the sample was as clean as oil straight from a new bottle.
Btw, my oil return is through the oil cap, not the valve cover.
2004 Jetta BEW 5M - 475k - 51 mpg / Fuel B-20 / Fuel Filter - Cat IR-0750 /
Oil Filter - Hengst / Oil - Schaeffer Supreme 9000 5W-40 /
Bypass Filter EaBP100 /
Air Filter - EaA208
/ Transmission Oil - VW G50
phaser is offline   Reply With Quote
Old August 10th, 2018, 13:26   #5
Lightflyer1
Lightflyer1's Avatar
If you do decide to remove it, keep everything and put it up for sale here. Others are looking for these and they are no longer available new. Your garbage is someone else's treasure.
2015 Beetle TDI.
Old August 11th, 2018, 10:39   #6
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
While there is cross hatching on the cylinders yet at high miles and it seems the oiled engine parts aren't what takes the car off the road (accidents, lack of maintenance, rust seem to do their part) I don't see a negative of having it either. It should keep the oil better, it helps with a little oil cooling and gives extra oil capacity along with the oil seems less cycles of wear due to more oil.
In the end it is personal preference. No harm or benefit really. Not like the K&N air filters which almost all can agree what they do.
Sent from my SM-G950U using Tapatalk
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old August 11th, 2018, 11:53   #7
tdidieselbobny
I guess my biggest complaint is that if you don't drain the bypass filter, you still have a quart of used oil getting mixed in with the new oil, as I didn't see any drain valve on or around the bypass.
Old August 11th, 2018, 16:42   #8
Ol'Rattler
Ol'Rattler's Avatar
Since you are getting a new valve cover anyway just delete the bypass filter. Less hassle and expense during an oil change for an additional filter that essentially does nothing to prolong the service life of your engine.
A bypass filter routes some of the oil pumps volume back to the crankcase making less oil volume available where positive pressure lubrication is mandatory to prevent excessive wear on moving parts.
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
WTB: Dieselgeek oil bypass for BRM relumalutan Private TDI Items for Sale/Wanted 0 December 26th, 2017 16:27
Dieselgeek bypass oil filter kits available again! ctnatureboy Fuels & Lubricants 104 September 1st, 2015 12:58
DieselGeek Oil bypass - $300 JasonCzerak Private TDI Items for Sale/Wanted 1 July 7th, 2014 05:00
dieselgeek bypass oil filter kit durbo Private TDI Items for Sale/Wanted 7 April 22nd, 2013 01:30
WTB: Dieselgeek bypass oil filter VATechTDI Private TDI Items for Sale/Wanted 2 April 20th, 2008 22:24
Page generated in 0.35292 seconds with 12 queries
[Output: 92.95 Kb. compressed to 80.50 Kb. by saving 12.45 Kb. (13.39%)]
