Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old August 10th, 2018, 10:32   #1
The4ork
The4ork's Avatar
Default Coolant fans not working or intermittent with a/c on
Hi folks. I was having intermittent cooling fan operation, noticed by my a/c kicking on and off in city driving/red lights.
So i replaced the main large fan with new. seemed to work flawless for a day (probably coicidence) and im right back where i started.
I thought maybe i didnt connect the main electrical connector all the way so i jacked the car, pulled the lower cover off and right before i stuck my hand on the connector my fans randomly kicked on for the after-run function. I thought that was very odd.
Perhaps its the a/c pressure switch? as in the pressure had changed while it sat for 10 or so minutes while i was jacking the car and removing the cover?
any help would be greatly appreciated. I dont have a vag com and plan on getting some help later today but its not a guarantee i'll be able to do it.
The4ork is offline   Reply With Quote
Coolant fans and AC not working 2001 jetta tdi wag VW MKIV-A4 TDIs (VE and PD) 4 April 30th, 2015 16:02
Both Fans not working Purch VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 2 April 26th, 2015 14:01
Radiator Fans not working, AC intermittent. Cracker VW MKIV-A4 TDIs (VE and PD) 14 May 28th, 2013 13:54
FS: *** Coolant System Parts (radiator, fans, shroud, coolant lines, reservoir) INCLU GotEuroCorrado Private TDI Items for Sale/Wanted 6 October 4th, 2012 07:09
coolant sensor changed still get intermittent red flashing coolant light jsweatte TDI 101 18 August 23rd, 2009 13:59
Page generated in 0.12437 seconds with 12 queries
[Output: 48.21 Kb. compressed to 45.39 Kb. by saving 2.82 Kb. (5.86%)]
