hi I have 2 tdi golfs a 02 and 00 both 1.9s how could oil get fuel in it? just put new head and gasket im a pretty good mechanic and all new quality timing set the old belt was broke all is in time used the tool set
At least with off road (red) diesel, the quickest easiest way to find fuel in the crank case is to drop a couple drops of oil from the dipstick onto clean white paper and fuel will quickly leach out away from the oil.
Does it start hard? Mechanical injectors that leak down usually seem to make harder smokier starts from fuel dripping past the metal to metal seal of the needle. But that's a severely worn injector
