2000 jetta tdi automatic to a manual ?
stebbe
Troup, TX [ southeast of Tyler ]
2000 jetta automatic
How involved is it to convert an automatic to a manual trans? Engines are the same for the manual except for the injector pump, right? Is it OK to use an automatic engine W/a manual trans?
Steve Yoerger
G60ING
MD
No TDIs Currently, I have an R36 Corrado. I've had an ALH Corrado swap, AHU Corrado swap and 2003 TDI Jetta
Steve Yoerger
if it is possible it should be very stingy on fuel. Take a look at the schematics for your car. there are separate wiring diagrams for autos and manuals compare and digest
Hasenwerk
Vendor , w/Business number
Quesnel, BC
1982 Cabriolet (BEW|VNT17|Stage4), 1989 VW TriStar Syncro soon-to-be CR TDI (CBEA), 2001 Ford Ranger Edge 4x4 (ALH|VNT17|R520|Stage4)
Steve Yoerger
Are you swapping gearboxes or replacing engines here? The differences between manual and automatic ALH engines is the coolant glow plugs - the automatics have none. Yes the injector pump is different, but the injectors are different too so the power output is the same.
Hasenwerk
Quesnel, BC
Fortuna Wolf said:
Let's say that we're just switching out the gearbox.
The coolant heaters and the injectors won't matter - the only thing that you would have to do is change the software coding to be automatic so that it won't look for a clutch pedal.
Fortuna Wolf
Wilmington, NC
2002 Jetta TDI Auto Sedan
Well, what would be involved physically? Remove the automatic and its shifter, and replace with a manual transmission, shifter, add a clutch pedal...
We'd have to connect the manual transmission to the brake fluid reservoir, right?
