chris_b
The "ignition" key in my 2006 Jetta TDI suddenly has become very hard to turn. The first time it happened, I wasn't sure I was going to be able to turn the key far enough to start the car. I had to apply more pressure that I was comfortable with to move the key to the on and then start positions. Once in the "on" position, the key moves easily to start (crank).
This happens with the steering locked and no pressure on the key. I applied some Triflow in the lock mechanism and that helped quite a bit for a while, but then the problem came back in a week or so.
I am concerned that the time will come when I will not be able to turn the key at all and I will be stranded somewhere.
Has anyone else had this problem, and if so what was the solution?
