Map sensor grommet small sensor to bigger hole
Edward0712
Denver,co
03 Volkswagen jetta (alh)
I found this grommet at oriellys, it works really well & air tight
U will need to get longer bolts with washers ,
The map sensor is hard to push in, I would recommend a dap of grease on the oring
Sent from my SM-G950U using Tapatalk
Nero Morg
OR
2014 A6 TDI, 2001 Jetta TDI, 2014 Passat TDI
Just as an FYI, vendors sell the adapter. They're ridiculously cheap.
Edward0712
Denver,co
I know, but I was in pinch trying to get the car done today
Couldn't find anyone in Denver that had one , had to use what i could find
& it worked [emoji4][emoji4]
Nero Morg
OR
Makes total sense, good find!
