matada34
Hi,
I have the dreaded panoramic roof leak problem, both A pillars get wet but now it dripping through the head lining and soaking the seat.
Ive poked some strimmer cable down the front drain holes, the passenger side would barely go in where as the drivers side (which leaks) went in to a length of approximately the dash board area.
Im guessing the pipe to sun roof attachments are off or leaking.
Has anyone got any clear guidance on this relating to the B7?
Im thinking I need to have a look behind the roof lining to see whats going on, im a bit of a wimp when it comes to head lining!
If I park the car on a hill, front end up there is no leak, I guess the rain runs down the back drain holes.
Thanks for looking, thanks even more if you can help!
Cheers Matada
Cheers Matada
