79TA7.6
- Joined
- May 8, 2006
- TDI
- 2003 TDI Jetta, 2002 TDI Golf, 2005 TDI Golf
I had purchased a used starter a few years back with intentions of rebuilding it. I found out that it was an aftermarket starter so I did not want to waste the time on it. I took it all apart and cleaned it and put it away. Last year during the cold, right around zero, I had an issue where my starter would turn over a few times then just kick out. I decided to put in the used starter I had bought a few years back. All has been good up until yesterday. It was about 10-15 degrees when I tried to start my car yesterday and all my car wanted to do was click when I hit the key. It would only click once. Thinking the battery might be suspect I hooked it up to my pickup to jump start it. I have started many big tractors with my pickup in the cold so I know it is more than capable of doing it. When I tried the first time it just clicked again. I tried it again and it started right up. I drove it into town about 8 miles where I shut it off and started it multiple times. Drove it home again too. Now this morning all it wanted to do was click. I did not try to hook it up to my truck, but I did tap the starter a few times with a metal rod. Still nothing. I have not tried it again.
What are the chances that it is the battery even though it clicked the first time I tried it yesterday with the truck hooked up? I know it can be the connections as well, so I will be checking those. I am trying to gather as many things to check before going to work on it. It is only about 20 degrees out right now and I don't have any place to work on it but outside.
Also, I want to rebuild the original starter. I am trying to find a rebuilt kit, or list of parts to buy separate. Does anyone have such a list and a reputable place to buy them? Do out normal parts guys, Bora Parts, IDParts, and the others carry them?
