Joe Rappa
A week ago I started burning Biodiesel in my 99.5 Golf. I have spent the week comparing my emissions running both Biodiesel and Petrol Diesel, and found some interesting results. I've posted the charts below
Biodiesel has the reputation of creating increased NOx emissions, which it certainly does, but not by much. It is a little high at a 60 mph and 75 mph cruise..but is significantly lower at WOT.
1300+ppm with diesel,
Under 1000 ppm with Biodiesel.
I also believe that Biodiesel is lower under any type of acceleration, but I can't superimpose my graphs from the scanner and gas bench. I have been trying to display a chart of engine load and gas numbers at the same time…but it hasn't worked out yet….they have different display rates.
I haven't tried any modifications on my car in order to address the high NOx but I will in another week or so. The tests shown here without EGR connected(there are enough variables without having to worry about EGR percentages too.) Also, please note the differences in O2 levels. The numbers on Petrol diesel look normal to me for a Diesel, but the numbers on Biodiesel are high. I thought that my O2 sensor had failed but it calibrated OK. I tried another sensor, and then another gas bench. They are correct as far as I can tell. The only reason I can give for the high O2 is that maybe there is a significant amount of Methanol left over from the procedure, making it an oxygenated fuel.
Both HC and CO numbers are very low as is expected with a Diesel. They are always at or near 0 once operating temp is reached. I don't have a measurement of soot levels(opacity), but there is quite a bit less soot with the Biodiesel. I have 250 miles on 1 gas bench filter, and still going.
I have additional graphs on WOT runs if anyone wants to see them.
This one is the Biodiesel run...
This one is the Petrol Diesel run...
[ May 17, 2001: Message edited by: Joe Rappa ]
