treetopflyer
As per subject, I want to know how to check for acceptable pad wear ( so I get maximum service life before replacement), without damaging the rotors. I have no abnormal braking, pulling, noises, and as far as I know these are the original brake components at 74,000mi. on the odometer. I have read numerous "brake" related threads, without adequate results, but they will be IMMENSELY HELPFUL when it comes to actually performing the work. Thanks to all that have taken the time to document their work!
My vehicle was always dealer maintained due to job/time constraints. During the last service the inspection noted brakes 70-85% worn. Well I have found a job with a more compatible job schedule, but no dealer within a 130 miles, which means I'd better get repair savvy fast and start doing my own maintenance!!!
Now the questions: 1-brake wear indications i.e. puck min. thickness, warning lights, (time to replace), 2- do I need to replace the rotors every time I do a brake job even if the rotors have no scars or gouges? 3- Do VW rotors have enough meat to have them turned, or are they one time use only?
I will be purchasing a Bentley manual and acquire the related special tools for service and system flush.
