Dieselforever16
2003 Jetta wagon TDI GL with an ALH manual
300,000km
Background: the past 2 weeks or so I’ve had an engine code thrown up “P0234” which I solved by finding a hole in my vacuum line off the N75. I replaced all the lines just because. Code was still there, so I chased the wiring harness and found a broken wire off the N75 plug. Replaced it and the code went away, but my car would still get put into limp mode with no codes now. Now it only goes into limp mode on the highway over 90km @ 2900 RPM. Until today. Now I don’t think it’s in limp mode.... but it’s very similar except I can HEAR the turbo spooling very loudly. There’s blue smoke pissing out the back like a fkin locomotive and I have no power as if the turbo is not working. No engine codes.
I’m at the point where I want to set it on fire and off a cliff. I have not a clue what’s wrong as I have no codes, I can hear the turbo spooling (louder than normal).
Any ideas or tips would help.
300,000km
