brenner
- Joined
- Aug 1, 2003
- Location
- british columbia,canada
- TDI
- 1960 mercedes benz 180db2001 jetta gls tdi silver,2000 golf gls tdi,2002 dodge 3/4 cummins ho souped up
the coolant fans on my 2000 golf tdi will energize as soon as the ignition switch is turned on even on a cold start,the only way to disable them is to pull the 30 amp fuse located in the battery box,no codes are shown on the vag com, I suspect the coolant temp sensor switch has gone south. The temp sensor switch checks out ok .did anybody experience this problem? any suggestions will be greatly appreciated. thanks
