bdmartinek
Hi!
I just had the transmission fluid changed for an automatic transmission, 02 Jetta. I was planning to have the differential fluid changed as well, but the shop said that the differential wasn't separate from transmission. I thought that this was true of the manual transmissions but not of the automatic. Can anyone confirm this? If the differential fluid is separate from the transmission in an automatic, I want to make sure I have the fluid changed. It would need to be done.
Thanks for you help.
(If the differential fluid is separate, can someone please tell me how you locate and access it, and how much fluid it would take to change it over.)
