Thank you, Rogue.
There are also these:
"...Mammalian cell genotoxicity:
• Gasoline PM
strongly active for DNA damage and for chromosomal damage
• Diesel PM
weakly active for DNA damage and for chromosomal damage
• Gasoline SVOC weakly active for DNA damage;
strongly active for chromosomal damage
• Diesel SVOC
inactive or weakly active for DNA damage or chromosomal damage..."
Source: In Vitro Genotoxicity of Particulate and Semi-Volatile Organic Compound Exhaust Materials from a Set of Gasoline and a Set of Diesel Engine Vehicles Operated at 30 Degrees F
M Ensell, M Keane, T Ong, W Wallace
National Institute for Occupational Safety and
Health, Centers for Disease Control and Prevention
"…The smaller particulates from gasoline engines, currently unregulated, present a significant health risk….
Source:
http://babbage.me.ic.ac.uk/department/review97/th/thrr11.html
"Emissions of extremely small particles (Dp < 10 nm) at high road speed may be
very high (10^14 - 10^16 part./kg fuel) even for nominal low emitters [gassers].
-Number emissions from two classes of SI engines may
equal or exceed Diesel levels
– Normal emitters at high speed and load
– Worn engines with high oil consumption
-The Swiss EPA has proposed that Europe adopt a solid particle emission standard of 10^11 part./km
– This corresponds to roughly 10^12 part./kg fuel
It is unlikely that our current on-road gasoline fleet meets this standard
– Will gasoline engines need exhaust filters?"
Source: Gasoline Vehicle Exhaust Particle Sampling Study, David Kittelson, et al, DEER 2003 Conference,
http://www.orau.gov/deer/presentations/session9/2.%20Kittelson%20-%20DOE%20DEER%202003%20rev1.pdf
"…since gasoline vehicles are now proven to emit substantial amounts of PM and "toxics," the current exclusive regulatory crackdown on diesel vehicle PM doesn't quite hit the clean-air bull's-eye, scientific studies indicate….
…researchers once again exploded the "myth that gasoline doesn't put out much elemental carbon. Well, it does," Kittelson said, "especially under cold-start--there's
a lot of elemental carbon…."
Source:
http://www.findarticles.com/cf_dls/m0CYH/17_7/109443861/p1/article.jhtml
"…Gasoline vehicle exhaust is enriched in particulate PAH as compared with diesel exhaust…."
Source: DOE’s Gasoline/Diesel PM Split Study
Eric M. Fujita, David E. Campbell, William P. Arnott, Barbara Zielinska and Judith C. Chow
Division of Atmospheric Sciences
Desert Research Institute, Reno, NV
Douglas R. Lawson
National Renewable Energy Laboratory, Golden, CO
"…The cancer risk index is…higher for gasoline vehicles than for diesel vehicles…."
Source: John Fairbanks (DOE), Symposium on Particulate Matter, August 12-13, 2003
