Not starting after rebuild! Any help?
Hi there. About 2 months ago my husband bought a 2000 Jetta TDi from a guy. The car is a savlage vehicle with front end damage. The previous owner had intended on repairing the car for himself and purchased most of the parts to fix it and never got to it. We really wanted to buy a diesel and figured this would be the cheapest way to do it so we thought we would take a shot at repairing it.
As of now, the engine had been removed from the car, the rack and pinion has been replaced. The transmission had a crack in the casing that has been welded We replaced some engine mounts. It has new brakes and rotors, new timing belt, glow plugs, and starter. The engine has been put back in the vehicle and all hoses/plugs are re-attached. Also replaced, new battery, new fuel filter (used vac to bleed the lines and see fuel and about 1-2 inches of air in the clear fuel line), EGR valve (ASV is opening OK), air filter, radiator and condenser.
We tried to re-start the car. The engine is turning over but will not fire up. We see 12 volts at the glow plugs and fuel-shut-off wire (it also clicks on start attempt). Also put some "Heet" in the fuel filter and fuel tank in case there was water from sitting. We plugged in an OBD2 reader to the car and are getting no codes, but the check engine light is on. (the airbags did go off in the original accident and have not been replaced yet, that may be why the check engine light is still on?)
Whitedog's post
http://forums.tdiclub.com/showthread.php?p=1972368#post1972368 on starting problems has been most helpful, but I still haven't figured my problem out.
If anyone has any ideas on how to get it started, I would love to hear it. We're running out of ideas. Also we live in Anderson, IN if anyone wants to come check it out. This is my last effort before we have to take it to a shop and let a real mechanic look at it.
Thanks,
