My compressor does not power up even when system fully serviced. I believe that my A/C compressor is bad and needs replaced. How do I confirm this?
TLIB in Annapolis
Most likely your AC realy under the dash. Either # 386 or 387. You could also check to see if you have voltage at the green connector plug. My bet is the relay though. Very common.
