Old May 20th, 2017, 10:28   #106
Macradiators.com
Macradiators.com's Avatar
Rollers or no rollers 420hp bmw just did 11.6s on 402m
A5 manual transmission and worse injectors ever. 420hp did 11.9s
Both cars street legal diesels, fully equipped.
These guys drove 800km to get here. Geez
Its time for bigger turbos for bmw.
Sent from my SM-G935F using Tapatalk
CP3 Upgrade
Macradiators.com is offline   Reply With Quote
Old May 20th, 2017, 15:38   #107
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
Not in this country. Most of the dynos used for emissions are small roller dynos.
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old May 20th, 2017, 16:25   #108
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
The size of the dyno rollers doesn't matter for emissions testing because vehicles are tested at speeds corresponding to national speed limits and never tested anywhere near their rated power. Tire deformations are lower and do not factor in much when the key is following a speed-time course rather than measuring outright acceleration rate and power output. It is nevertheless quite certain that certification centers are not using Dynojets, Dynapacks, Mustangs, or any of the brands commonly used in the aftermarket LOL. Each testing body will set standards and procedures, and repeatability and consistency are far more important than what technology of roller is employed.
Edit: About dyno losses, AWD and slushbox automatics will have larger driveline losses, but not in the order of 30% and certainly not linear to the engine output
http://forums.tdiclub.com/showthread.php?t=75062
If there's ~100kW lost at the driveline or tires, you will definitely see this with infra-red imaging - actually you won't even need to - your tires will certainly melt and your transmission/differential will need forced cooling with massive heat exchangers.
Old May 21st, 2017, 01:04   #109
Bobby Singh
Bobby Singh's Avatar
TDI(s): Audi 3.0 TDI
Impressive time for the A5 - What kind of timing gear are you guys using? Please don't say a casio stopwatch.
The reason I ask because even with 440hp/900nm I can't get into the 11's
This is with 900nm take off from the line in a TIP gearbox
Best I can get at santa pod is 12.3
At another drag strip I managed 12.1
But never 11's
So far you have stated a 100 to 200 of 7.x whereas everyone else is in the 11.x with sameish power
1/4 miles time that appears be unrealistic
Would be nice if you can post vcds logs with speed and time stamp.
BSR
Audi A4 3.0TDI B8 - 440hp/900nm...
Bobby Singh is offline   Reply With Quote
Old May 21st, 2017, 10:34   #110
Macradiators.com
Official certified timing gear from USA, its international event.
You can contest any dyno number you want, but you cant comment about timing :P
Today we had cars from BG doing 9.1s , Moldova GTR godzilla done 8.7s , gti 9.5s , 911 1250hp porsche constant 9.7s, r35gtr 1000hp 9.8s
No bike went under 10s, 10.2 was best
Tdi cars were a disappointment, lupo tdi 4x4 12s , lots of 2.0 pd in 12.x seconds
2 identical cars at 400hp from different tuners will never go identical..1 will always beat the other
Owner will present his car on the forum shortly.
Details later.
Meantime from car's CAN
Lots pf cars 3.0 doing 12.1-12.2 , 2.0 class was not so strong, lots broke
BMW doing constantly 1.6-1.7s 60ft and about 10runs at 11.7 , 3 runs at 11.6s
CP3 Upgrade
Old May 25th, 2017, 23:06   #111
eddie_1
eddie_1's Avatar
Congratulations! Looks like eastern europe cars are much more powerful and faster. Actually not a surprise for me.
'03 Jetta Wagon TDI, 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy,Front/ Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, thermometer, Hidden Hitch, LED tail lights, Koni Reds, Depo Proj
eddie_1 is offline   Reply With Quote
World Record MPG TDI For Sale Beeah TDI Cars for Sale/Wanted 0 April 14th, 2010 00:13
New Guinness mileage Record TDI/Goodyear fgbrault VW MKV-A5 Golf/Jettas 9 August 21st, 2009 19:59
TDI speed record Jester General VW Discussion 2 April 28th, 2009 13:15
TDI Reliability Reputation/Record Rickdude TDI 101 30 September 11th, 2005 19:14
TDI Land Speed Record suffeks VW MKIV-A4 TDIs (VE and PD) 35 January 20th, 2004 13:21
Page generated in 0.13584 seconds with 12 queries
[Output: 83.02 Kb. compressed to 72.90 Kb. by saving 10.13 Kb. (12.20%)]
