Fault codes Help
tverhoeven
Just got these codes from my 2003 Jetta TDI automatic. Any help would be greatly appreciated. I just bought this car used a month ago and it is running great but last week the MIL light came on and this is what I got.
thanks
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 GN
Component: 1,9l R4 EDC G000AG 4308
Coding: 00001
Shop #: WSC 00066
3VWSP29M63M123192 VWZ7Z0B6209630
1 Fault Found:
17058 - Cylinder 4 Glow Plug Circuit (Q13) Electrical Fault
P0674 - 35-10 - - - Intermittent
Readiness: N/A
Address 02 -------------------------------------------------------
Controller: 01M 927 733 MK
Component: AG4 Getriebe 01M 5023
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
01192 - Torque Converter Lock-Up Clutch
04-10 - Mechanical Malfunction - Intermittent
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00066
1 Fault Found:
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
Address 56 -------------------------------------------------------
Controller: 3B7 035 180 D
Component: Radio ZSW 0010
Coding: 04401
Shop #: WSC 00066
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End -------------------------------------------------------
2004STARWARSTDI
LAKELAND, FL
2004 Platinum Gray GLS Jetta / 2006 Silver Jetta with DSG
Codes
Try these solutions
thanks
1 Fault Found:
P06
Test glow plug cylinder 4 R&R also check,clean glow plug harness
1 Fault Found:
Transmission for this year not very good, try replacing filter and fluid, probably need torque convertor
1 Fault Found:
R&R ignition switch
1 Fault Found:
R&R (remove and replace) antenna base
