Old May 12th, 2019, 14:25   #2611
SLF-951
Unfortunately I don't know at this time. The scanner I have doesn't support airbag diagnostics on VW's. Guess it's time I buy my own Vag-Com so I can code this one to manual and figure what happened with the airbag system.
SLF-951 is offline   Reply With Quote
Old May 12th, 2019, 21:46   #2612
alphaseinor
Yeah, and even if you fix the problem, the light will stay on until cleared.
alphaseinor is offline   Reply With Quote
Old May 16th, 2019, 14:35   #2613
SLF-951
Got the Vag-Com today, cleared the airbag code, was low voltage something, didn't come back. I did have some things disconnected and had the key on several times during the wiring. So just a fluke. Coded for manual transmission and everything is working fine with the swap...
Now onto this : 01435 - Brake Pressure Sensor 1 (G201): Electrical Fault in Circuit. No ABS light, but the ESP light has been on since I bought it
Page generated in 0.11869 seconds with 12 queries
[Output: 58.67 Kb. compressed to 53.43 Kb. by saving 5.25 Kb. (8.94%)]
