audi A3 BKD engine rough idle difficult hot start
cypher007
UK
SEAT Toledo, Audi A3
what should i check/replace first on the BKD engine to cure the rough idle? ive checked with vcds and have 2 glow plugs, or wiring to them, that is faulty. also i find it takes quite a bit of cranking when its hot to start it. for now ive patched the idle issue by increasing the idle to 900rpm, though i can still feel the odd misfire.
is there a definitive test procedure/values in vcds to check which sensor is knackered?
i did some googling and found some people have replaced everything from the crank sensor to the fuel temp sensor.
cypher007
UK
p.s. apparently its had a new starter motor according to the previous owner.
cypher007
UK
need to test but think it was the battery not spinning the engine fast enough.
k_pt
pt
VW MKIV TDI
misfires? rough idle?
My suggestion is to start by getting values from injector deviations (group 13), to trace any faulty cylinder.
Then a compression test.
cypher007
UK
the rough idle is probably the exhaust valve timing. ive run diesel purge through it and the deviations have improved, they were pretty good anyway.
I did notice bubbles in the return line though which increased when I revved the engine, so I might have a leaky injector seal.
