Outer hub bolt is a 30mm, and you'll need a SERIOUS breaker bar to get it loose. I recommend not using a rachet, unless it's a Craftsman so that they'll replace it if you bust it. /images/graemlins/laugh.gif Take your wrench to Home Depot and find about a 4 foot length of iron pipe that will fit snugly over your wrench. That will give you all the torque you'll need.
Loosen the hub bolt with the car on the ground (obviously) then you can raise it in the air and loosen the triple square bolts on the inner CV. You'll probably have to loosen a couple. Take the car out of gear, rotate the wheel 60 degrees, loosen the next couple, repeat until all the bolts are out. Be sure to use a hammer and tap that triple square into the bolt head nice and tight. You don't want that thing slipping and stripping.
Then you're at the hopeing point, because you may or may not have enough clearance to get the halfshaft out. Try and pull the inner CV away from the tranny flange. Then try and work the shaft upward. If you try and try and still can't get it out, then you'll need to loosen the bolts that hold the lower ball joint to the control arm. This will allow the whole hub assembly to swing outward and give you the extra clearance you need.
The reason you hope to not have to do this is that those bolts are the wheel alignment camber adjustment. If you're careful and mark the position of the bolts before loosening them, you can get them lined back up pretty close to the original position, and won't need an alignment.
Once the you get the shaft free of the tranny flange, the whole thing will just pull right out of the hub. No pressing needed.
The shaft will probably come with some extra grease that you'll want to try and force into the open end of the inner joint. If it doesn't get yourself some CV joint grease so that you can make sure that is nice and juicy before re-assembly. The outer should be totally sealed.
Only thing that I'd recommend is replacing the big outer hub nut. As you can see from the torquing procedure, that thing sees some serious stress. I'd feel more comfortable with a new nut on there. Everything else is just pretty much bolt on. It's a couple hours of grunt work, and having a helper take the car in and out of gear when you're loosening and tightening the inner CV joint bolts is a big plus. Climbing out from under the car, taking out of gear, rotating the wheel, putting back in gear, climbing under car, only to see that you've over or under rotated is frustrating. Much easier if you can just ask somebody to take it out gear and you can rotate from under the car.
