Old October 23rd, 2018, 10:15   #16
Curious Chris
Fuel Economy: 47/42/38
Originally Posted by sizzlin bacon View Post
According to the shop, the timing is retarded and they said they will reprogram the IP. 1hr diagnostic+2hrs labor= $438
Does this seem out of line pricewise? I feel like I might be taken for a ride...
You did not even get kissed. Follow this link: https://store.ross-tech.com/shop/vchv2_ent/ You can get VCDS for $199 and you do the diagnostics and set the timing. Knowledge is power.
Curious Chris is offline   Reply With Quote
Old October 23rd, 2018, 23:32   #17
sizzlin bacon
Fuel Economy: 39
Turns out I need a new pump (as stated above). It is supposedly failing.
Any reviews/opinions on these rebuilt pumps here? Seems like a good deal and they're tested prior to shipping...
http://www.hansautoparts.com/RebuiltALHMTDIPump.aspx
Otherwise, the shop wanted $1600 for a new one through them or a rebuilt one offline through another parts store I found was $1299...
Alternately, the shop that did my timing belt said they have one on a running car they'd pull and install, plus do my timing belt at the same time for $1100+tax. Seems that's the route that is looking the best right now unless the Hans pump is legit and works well.
sizzlin bacon is offline   Reply With Quote
Old October 24th, 2018, 11:00   #18
flee
Fuel Economy: 40-ish
DFIS is in Portland and should be able to make your IP as good as new for about $750.
2002 Jetta GLS TDI wagon
flee is offline   Reply With Quote
Old October 24th, 2018, 11:43   #19
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Turns out I need a new pump (as stated above). It is supposedly failing......................................
Interweb evaluation- I doubt it.
Hoping you didn't go back to the folks that charged $498 and didn't fix it.
Me thinks you need to go back to square 1. Verify the correct code. Find a verified TDI mechanic. These cars are simple but different.
Old October 24th, 2018, 11:59   #20
eddieleephd
Fuel Economy: 38mix / 47@70-75
Take the pump to Portland and have them test it first. Find a local guru and have them look at it.
^^^you must take it in order to evaluate the situation.^^^
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, Stealth pipe, BMW Cyclonic CCV filter, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, fill tube ectomy, soon to be Wuzetem p.520 PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is online now   Reply With Quote
Old October 24th, 2018, 14:55   #21
sizzlin bacon
Fuel Economy: 39
They charged me ONLY $300 for the diagnosis and pulling apart the intake (for some reason they found this to be a reasonable thing).
So, today when driving it (and last night too) I did not get any error/engine light on the dash. I bumped up to 80MPH without issue. This is leaving me rather confused now, as it seems to be working as normal.
I can't say I'm too pleased with the service at that mechanic. I've been there three times and each time I feel like they're trying to sell me a load of crap. The place that did my timing belt said they'd throw the used one from a running (engine is good, transmission is shot) on and do the timing belt at the same time for $1100, which seems tempting as a timing belt is slightly less...
Are the HANS pumps not worth anything in this instance? I saw the description of them and the guy said he reverse engineered the pump. Too good to be true?
Old October 25th, 2018, 06:04   #22
eddieleephd
What did they take apart? if you had a boost leak and they took the boost hoses off and reconnected them it could have done the trick.
Hans is noted as questionable, I PM'd you with other choices; check them out.
Old October 25th, 2018, 12:16   #23
sizzlin bacon
Fuel Economy: 39
I did not receive your PM. They took apart (from what I saw) the "tube" that the anti-shudder valve is mounted on and a few other things off the intake. I really did not get a good look outside of that. The guy who was working the front showed me the anti-shudder valve pipe with some build-up in it, but it wasn't too bad.
A co-worker has offered to sell me his pump off his wrecked TDI (hit a cow!), but I am not sure if it is manual or automatic yet.
Old October 25th, 2018, 12:20   #24
eddieleephd
Look at the classifieds and see the options there
Old October 25th, 2018, 12:43   #25
BobnOH
not-a-mechanic
Not convinced you need a pump, interweb and all. If you know it's bad, try the pump from your co-worker, either 10mm or 11mm (auto) will work. If the car is now happy, drive on.
Don't know this Hans, if it's HansAutoParts.com, Prothe, Rothenbacher, run!
Old October 25th, 2018, 13:10   #26
tyberesk
tyberesk's Avatar
I'm in Washington State. I'll poke around and see if I can find someone.
Not sure where you are at, but could always reach out to Oldpoopie in Portland.
tyberesk is offline   Reply With Quote
Old October 25th, 2018, 14:54   #27
eddieleephd
You're not a newbie! no matter what the site says, you've been stalking! Stalker!
Old November 9th, 2018, 00:33   #28
sizzlin bacon
Fuel Economy: 39
So a little update. The light went away shortly after the shop reassembled everything. I thought it was all good! No light for quite a while. Then it came on almost simultaneous to the fuel light coming on last night. So, now I'm not sure what to do with it. I'm leaning toward taking it to a local VW guy who did my timing belt (shop seems to be reputable or at least better than the other...?) as he offered a used pump plus timing belt change for $1100+tax. I think I'm getting tired of older diesels...and want a car that just runs, even if it lacks spirit or character.
Old November 9th, 2018, 16:33   #29
super1
TDI(s): none
Default Error Code P0252 on 2003 Jetta Wagon
If your still having trouble with your TDI look up Dr Dan Biodiesel
https://drdansbiodiesel.com/
He has a lot of knowledge of TDI's & post a lot of fixes on YouTube
I don't know him but he might be close to you ?
super1 is offline   Reply With Quote
Old November 9th, 2018, 19:07   #30
STDOUBT
STDOUBT's Avatar
The MKIV TDI is not for everyone. Unless you're willing to do at least all the scheduled maintenance yourself OR have access to a trusted TDI mechainc (hint: if your mechanic didn't use VAGCOM or VCDS, he isn't one), then you may be better off selling it to someone who has the time to care for it better. There's plenty of us out there. IMHO even having a "good" euro-car shop work on them is a total crap shoot, most likely ending in crap. Even here on tdiclub, they are regarded as "hobbyist" cars nowadays.
2003 Jetta TDI 1.9L 5-speed
All Stock except: Ventectomy
STDOUBT is offline   Reply With Quote
P0252 error .... What's wrong ? Andyinchville1 TDI 101 3 October 30th, 2017 11:59
Error code P0401 on 2003 Jetta Wagon NOLAHusker VW MKIV-A4 TDIs (VE and PD) 2 October 4th, 2014 12:00
2003 Jetta TDI died on side of road! P0252 code! Help a girl out! :) silverdog91 VW MKIV-A4 TDIs (VE and PD) 4 July 11th, 2014 07:32
2003 jetta Diagnose~ P0252 and others. tdiseller VW MKIV-A4 TDIs (VE and PD) 8 March 30th, 2011 17:22
Code P0252 with Limp Mode on 2003 TDI - Help!! Glowman VW MKIV-A4 TDIs (VE and PD) 10 February 4th, 2010 10:02
Page generated in 0.17255 seconds with 13 queries
[Output: 136.58 Kb. compressed to 115.00 Kb. by saving 21.58 Kb. (15.80%)]
