Old November 8th, 2018, 18:47   #1
gr8smile66
Default Can heater/a/c controls be exchanged?
Hello-
I am getting ready to turn in my 2012 Passat TDI SE 6MT, and have already purchased a 2015 Passat TDI SE DSG.
I really like the climate control in the 2012 compared to the 2015. The 2012 came standard with dual climatronic which my 2015 doesn't have.
Does anyone know if I can swap the climatronic modules between the cars (and have the A/C and heat still work?) Would this need to be done at a VW dealership, if it could be done, and is there going to be a software change, as well?
Thanks in advance if anyone can help with this question!
gr8smile66 is offline   Reply With Quote
Old November 9th, 2018, 04:06   #2
goodmonkey
goodmonkey's Avatar
Greetings,
Unfortunately it isn't as easy as changing the controls. The entire air box behind the dash would need changing, as there are some different air diverters to allow independent side temperature control, along with servo modules, wiring, and sensors. It is quite a job, took me around 35 hours to swap mine in my 2006 Jetta. That could have been cut in half if I didn't run into problems, but that is another story.
2014 Passat TDI SEL (DSG) - 82k, 2007 Silverado Duramax - 425k
Previous TDI's: 1996 Passat TDI- totaled at 394k miles, 1998 Passat TDI - 175k miles, 2012 Passat TDI SE - 41k, 1996 Passat TDI Variant - 327k, 2014 Jetta SportWagon TDI 6MT - 29k, 2015 Passat TDI SEL - 18k, 2006 Jetta TDI 5MT - 261k
goodmonkey is offline   Reply With Quote
Old November 9th, 2018, 04:24   #3
oilhammer's Avatar
Fuel Economy: fantastic
Besides, the fewer made-in-China HVAC door motors you have buried in the dash waiting to fail, the better.
Because this sucks to have to do to a car that is barely out of warranty:
My 2004 Passat has had its dash out exactly zero times, 205k miles.
www.cardocautomotive.com
Old November 9th, 2018, 07:22   #4
compu_85
Gadget Guy
compu_85's Avatar
I guess it hasn't started blowing foam out the vents yet
Even the cars with semi-automatic climate control will have some door motors. Is the air direction control motor driven? I know the temp control is still electronic.
Regarding swapping to dual zone Climatronic, it's more than just the control head. The whole HVAC box is different.
-J
Present:
2018 Tesla Model 3 DM. 3500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
1991 Mercedes 350SDL 230,000 miles, 70,000 on engine. 18/27 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
1988 Audi 5000S Quattro, 1992 Jetta ECOdiesel, 1991 Jetta ECOdiesel.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Check out the official TDIClub Chat Room!
Originally Posted by BRUSSELS BELGIAN View Post
Maybe I should pay MYSELF to do bad work on my car!
compu_85 is offline   Reply With Quote
Old November 9th, 2018, 09:18   #5
goodmonkey
goodmonkey's Avatar
To answer Compu_85's question, yes, the air distribution on the Climatic (single zone) units is still electronically controlled. This is done with the air distribution door motor V428, located on the top left of the air distribution unit (as seen from the passenger compartment). In the A5 it was mechanically controlled via cable from the control panel.
So in the NMS Passat, Climatic has 3 control motors, Climatronic has 5.
Old November 9th, 2018, 09:47   #6
gr8smile66
Thank you all for the input.
I really didn't understand your replies, but I believe the short answer is NO, it can't be done easily, or by my husband (who is highly capable, but this isn't worth it)
Bummer, because I really liked the a/c in the '12 versus the '15....
On a positive note, though, I got to drive the 12 for practically free for the last 6 1/2 years once I turn the car in 12/4 (with only 56k miles) and get the buyback $$. Sad to see it go....
Thanks again for the responses!
Old November 9th, 2018, 22:44   #7
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
The easy answer to your question is that Yes, it can be swapped.
However, since you car does not have the climatronic box with the additional control motors and temp sensors, it will not work properly. It will not auto adjust the temperature, it will not operate two different temperature zones.
Fixmy59bug is offline   Reply With Quote
Heater Controls PLEASE HELP!!! DanisTDI TDI 101 9 August 23rd, 2006 15:07
Heater Controls PLEASE HELP!!! DanisTDI TDI 101 9 August 23rd, 2006 14:42
Heater controls light? roan65 VW MKIV-A4 TDIs (VE and PD) 3 November 22nd, 2005 11:58
Lighting for heater controls downhillboss VW MKIV-A4 TDIs (VE and PD) 7 October 5th, 2003 22:07
Ac heater controls stormgreywagon VW MKIII-A3/B4 TDIs 1 August 4th, 2003 19:20
Page generated in 0.13946 seconds with 13 queries
[Output: 85.73 Kb. compressed to 74.58 Kb. by saving 11.15 Kb. (13.00%)]
