Hey all, I just got my VCDS today and I ran a scan, wanted to see if anyone could give me tips on these fault codes I got.
Thursday,01,February,2018,12:47:49:59285
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.1.0.2 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180122 DS285.1
www.Ross-Tech.com
VIN: WVWAE63B75E078498 License Plate: N/A
Mileage: 342980km-213117mi Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: -- Mileage: 342980km-213117miles
Address 01: Engine Labels: 038-906-016-BHW.lbl
Part No SW: 038 997 016 T HW: 028 101 198 2
Component: R4 2,0L EDC G000AG 0314
Revision: 12345678 Serial number: VWZ7Z0D0714644
Coding: 0150034
Shop #: WSC 02172 444 90293
VCID: 2F3BEEC15B03352FC1F-5160
3 Faults Found:
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground - Intermittent
Freeze Frame:
RPM: 2037 /min
Torque: 172.0 Nm
Speed: 22.0 km/h
Load: 38.4 %
Voltage: 13.83 V
Bin. Bits: 00001000
Torque: 304.0 Nm
Torque: 170.0 Nm
19559 - Motor for Intake Manifold Flap (V157)
P3103 - 000 - Malfunction - Intermittent
Freeze Frame:
RPM: 2016 /min
Torque: 120.0 Nm
Speed: 33.0 km/h
Load: 27.5 %
Voltage: 13.83 V
Bin. Bits: 00001000
Torque: 268.0 Nm
Torque: 116.0 Nm
16618 - Boost Pressure Regulation
P0234 - 000 - Limit Exceeded (Overboost Condition)
Freeze Frame:
RPM: 3486 /min
Torque: 312.0 Nm
Speed: 65.0 km/h
Load: 100.0 %
Voltage: 14.21 V
Bin. Bits: 00001000
Absolute Pres.: 2386.8 mbar
Absolute Pres.: 2590.8 mbar
Readiness: 1 2 0 0 0
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 3B0 927 156 CF
Component: AG5 01V 2.0lPD USA 0505
Coding: 0001104
Shop #: WSC 00028 028 00001
VCID: 6C8139CDAA958E37A4D-5160
No fault code found.
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 04257
Shop #: WSC 05311
VCID: 25170CE90CFF7F7F3B3-51CE
Part No: 1C0 909 605 C
Component: 09 AIRBAG VW61 04 0003
Coding: 12345
Shop #: WSC 05311
VCID: 241111ED07C586772CD-513C
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 929 C
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 15235
Shop #: WSC 00000
VCID: 270B06E176F36D6F09F-513C
WVWAE63B75E078498 VWZ7Z0D0714644
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 05311
VCID: 70B92DBD83BD6AD7985-513C
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 08 Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 05311
VCID: 372BD6A1A653FDEF99F-4B1E
Subsystem 1 - Part No: 1C1959801
Component: 08 Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802
Component: 08 Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811
Component: 08 Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812
Component: 08 Tõrsteuer.HR KLO 0202
7 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
54-10 - Incorrectly Equipped - Intermittent
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00930 - Locking Module for Central Locking; Rear Left (F222)
00931 - Locking Module for Central Locking; Rear Right (F223)
01359 - Internal Central Locking Switch; Passenger Side (E198)
27-10 - Implausible Signal - Intermittent
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 G
Component: Radio PM6 0016
Coding: 00033
Shop #: WSC 00001
End----(Elapsed Time: 04:34, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
www.Ross-Tech.com
Coding: 0150034
3 Faults Found:
Freeze Frame:
RPM: 2037 /min
Torque: 172.0 Nm
Speed: 22.0 km/h
Load: 38.4 %
Voltage: 13.83 V
Bin. Bits: 00001000
Torque: 304.0 Nm
Torque: 170.0 Nm
Freeze Frame:
RPM: 2016 /min
Torque: 120.0 Nm
Speed: 33.0 km/h
Load: 27.5 %
Voltage: 13.83 V
Bin. Bits: 00001000
Torque: 268.0 Nm
Torque: 116.0 Nm
Freeze Frame:
RPM: 3486 /min
Torque: 312.0 Nm
Speed: 65.0 km/h
Load: 100.0 %
Voltage: 14.21 V
Bin. Bits: 00001000
Coding: 0001104
Coding: 04257
Shop #: WSC 05311
Coding: 12345
Shop #: WSC 05311
1 Fault Found:
Coding: 15235
Shop #: WSC 00000
1 Fault Found:
Coding: 00006
Shop #: WSC 05311
Coding: 00258
Shop #: WSC 05311
7 Faults Found:
Coding: 00033
Shop #: WSC 00001
