02 jetta automatic w/ 195K mi starts and idles perfectly fine. When I put in gear and go it hesitates a bit then 'kicks in". When driving on the highway about 70mph and hit an incline i give it some throttle it again hesitates and then "kicks in" causing a huge cloud of black smoke.
The exhaust recently broke right after the cat converter, I drove like that for about 1K mi before I fixed it.
I am headed to Autozone to see if there are any codes, my check engine light is on but has been on for a long time before this started happening. I know I should clear the issue but after addressing the glow plug code a few times decided to live with the light.
If the MAF is bad I would assume there would be a code to indicate such?
I am planning to replace the air filter and noticed in the forums I should check the "snow screen". Where is this snow screen?
Anyhting else i should be looking into?
Any help is very much appreciated
