ATLSilverTDI
I wanted to post a new thread noting that in the past 2 weeks I have noticed a tremendous increase in my MPG figures in my daily commute.
I am sure there are lot's of variables, and honestly I suspect it is the RIGHT foot that is effecting my mileage the greatest, however I will post what was done recently as a barometer to what's changed.
1) 32K miles, got another oil change. Done at Dealer, will try to post part number of oil, however in the past they have always put 505.01 oil not 507.00. I noticed that it said VR6 Oil/filter kit, but it doesn't tell you spec of oil.
2) Replaced brakes, rear were sticking something awful, I burned brakes rotors, was replaced by non VW mechanic, but parts are true OEM replacements that VW/respectable mechanic would use.
3) Temperature droppped from high 90's to mid 70's/80's
4) With above temperature decrease, less use of air condigitioning
5) Traffic is less stop and go than normally experienced (at least for past few weeks)
Again, I think I have been making a conscious or at least Semi Conscious effort not to step into the floor in my stop and go Highway traffic so I think that is helping and I am no longer doing 80-90-100 when the highway is open so I think that is a major factor, however I still do from time to time.
What do you think are the major factors in increase in mileage? I think the temps/atmospheric pressure and the less intense driving.
Other variables:
I blend some B20 from time to time, basically topping off a tank that is always above 3/4 full, as I don't want to go out of warranty bounds.
Problem is, I cannot scientifically measure how much I am blending ever 2 weeks, as I just top off where I am at.. 2 weeks Ago probably did 2+ gallons, this weekend did 5 gallons.
Appreciate your thoughts.
Constants: I am always using Pilot Truck stop gas as my base fuel, don' really mix that up much (although who knows what changes in blends from week to week from their supplier.
Other variables:
