I have been sitting on a low mileage ASV motor for some time now waiting for the right donor car... when all along it was right under my nose... my daily driver!
Its at the end of a long road, but hopefully on to better things. I want to build this car for efficiency... hence the computer control... and I am looking for something to tinker with for a little while so the more wires the merrier...
Anyways, as I don't have any pretty pictures to share (yet), I'll start with some quick questions...
Are there any differences between the ASV motor and an ALH electrically (different wiring colors... anything?) I have the Bentley manual, hoping it will will be of use...
My ecu is from a Seat Leon from what I could find from application tables (i don't have the number or I would share it, i will get it next time i have the parts in front of me... looked it up a while ago).
I was wondering if there is any options with the euro ecu to make it more stand alone. I would like to avoid using the instrument cluster/immo key for this car. I don't know if it is possible for a programmer to remove the need for the cluster(i know the immo, but what about the cluster as well...). I don't know exactly what kind of processing the cluster may do for the ecu or if the ecu could be recoded to run alone with the pedal cluster and other sensors... any programmers have an idea of what they could do for me???
If its not possible its not the end of the world, it would just make things a little less crazy with the wiring.
Does the asv have the same data link as an alh? if not, can it be rewired to work with one?
The motor is sans alternator, I was thinking of not adding another variable and just getting a stock replacement... but this is a frankenvehicle so an upgraded alternator would be fitting. I know people use GM alternators on the older ahu/1z swaps, but I was wondering if anyone had any better ideas?
I guess the only other big thing is are there any other big differences between the ASV and ALH... I am assuming that other than injectors, turbo, and the ecu programming they are interchangeable... please correct me if I am wrong.
...I know, I know... I've got a long road and a bunch of wires in my future...
