I was junkyarding because my existing sway bar is super rusty and had some flats worn into it and I wanted a better condition one. I found several sway bars all with the same black round thing around them right behind the bushing/mount, but some were intact and really on there.
I then found an ECS tuning link for a genuine 23mm sway bar and
you can see them pictured here. I think these are stops on the sway bar either for install to locate the busing/mount or to prevent left/right movement of the bar while driving.
Anyone know if these are necessary, as in, if your sway bar has these cracked off, it could be bad? Some other sway bars don't have these, but they have a different bend style where there isn't a straight run of rod right behind the bushing. Could my bar jump left/right without them?
edit: Found further info, apparently lateral bar movement is possible and negates the stabilizer bar's effect. The stops on the factory swaybar are an integrated part of it.
An aftermarket solution exists here
edit2: Aftermarket stops DO NOT FIT this bar, do not buy them. Clearance on the subframe is too tight for anything else, but the integrated factory original stops. I had to go to a few more junkyards before I found a complete, intact sway bar on an '06 new beetle ($15). Many bars will have no rust, but the stops are starting to separate in half when you take it off and look. Some have 1 stop left that looks great, but the other has fallen off. My car feels great now that everything is on there and fully functional. I wonder how many people are driving around without the sway stops and whether it matters or not?
