MORTAMIR
So i been getting this code more often recently. Before it would come and go. Now it is summer and i wouldn't think i would have a problem with my coolant temp being low but my ECU keeps showing this code. I don't have a VCDS. I just use Torque to scan when i see my almighty engine light come on.
So the help i need from you all would be, Starting with the least cost first, what would be elimination process to get this code sorted out?
I have a 05 BEW M5 with 207k. EGR valve and cooler delete, new turbo, new (to me) BRM intake manifold, new 3inch exhuast turbo back, new map Sensor, New tune all within the last 30 days.
EDIT: I also replaced the large fan recently.
Could this be a problem with my new tune?
I dont have a garage or many tools either and my wife has been laid off from work so we are a bit down right now.
I have read through a couple of discussions about this.
https://forums.tdiclub.com/showthread.php?t=359453 Seem like a place to start for no cost.
Just to confirm this is one the thermostats i would need to replace?
What is the other one?
