Had a very disturbing failure in my 2014 JSW tdi when the blower motor stopped on the first day of driving the car. After searching the forum for a diagram, I gave up and decided to just check all the fuses in fuse box c on side of dash. All were good , except the one I could not remove.
Waited until this morning for better weather and daylight to try to extract the only 40 amp fuse in the fuse box. Could not remove without removing bolts holding box to dash and then separating front and back of box for better access. Fuse was melted , not just blown. Thought it did major damage to plug in box, but metal clips were still intact. Plastic is a little worse for wear. After cleaning up plastic and metal bits in plug area, I placed a 30 amp ( no 40's on hand) to see if blower had been fried and caused the problem. Blower works, but need to know if I can move the lead to an unused open plug due to plastic damage on existing plug area. I hate the idea of having the whole box replaced and rewired. I have some warning lights on the dash that were probably caused by disconnecting each fuse. Will need to check on what they mean. I only drove the car for the first time yesterday, for 10 minutes . Not a very good start to the relationship. The whole problem may have been started by plugged sunroof drain water.....Followed the forum info and fixed those earlier today.....I hope. Thanks for the great info everyone. 61k miles, All black, nice looking.
