gotsoot
Needing a Houdini who knows how to change the diff. fluid on an`04 passat.why in god`s name did they not put an easier access to this.!!
My 254K mile B5 with an auto transmission just started dripping a little of fluid from the differential housing. This is the ribbed housing to the right of the transmission pan. What could be causing this leak?Typically does not need to be "changed", which is why they made no provisions to do so. You just check it at the side plug, but if it doesn't develop a leak, no real reason to do even that.
