This is a great thread. Thanks Tmpa and other contributors for the info. It would be great if this were in tutorial form which I may put together when I attempt it. I have very little experience with doing A/C work, but I do intend to try this repair (hey, you have to start somewhere, right?). Before I begin, I want to get some advice from the A/C veterans out there. My A/C started blowing warm and when I started researching/troubleshooting I found that both of my radiator fans were totally dead. Neither one was functioning. I knew the small fan was bad and out of laziness I had allowed it to languish for YEARS at the advice of a VW Dealer mechanic who said as long as the large fan didn't fail, there would be no problem. Had I known then what I know now, I would have RUN home and bought the fan when I heard that advice. In any case, I may have paid the price.
Both fans have been replaced and are working (two fans running at low speed when A/C button pressed in at max cool setting). I observed the compressor and pulley. Clutch engages when A/C is on and compressor turns. When A/C is off, the pulley rotates but compressor is not engaged. I get about 20 psi pressure differential between the high and low pressure ports on the A/C loop when A/C is on. Static pressure is about 110 psi at 95 F ambient.
After all of that, my question is: given that possible failure mode (compressor running hot and cycling because of multiple fan failures), is it likely that this solution (replacing the control valve) will work for me or is it more likely that the compressor itself is toast?
I appreciate any advice that you guys might have. If I can learn enough about this to attempt this repair myself, I will write it up in tutorial form and post for others to benefit.
Luc
