DRbillZ
- Joined
- Mar 17, 2003
- Location
- Jackson,Tn. Home of Carl Perkins :)
- TDI
- New Beetle, Jetta, one totaled Passat....RIP.
LEt the fun begin..................
Uh.......OK. Just wanting to see waht people thought of the product. Was trolling for responses, yes, not problems or flames.tditom said:blatant trolling reported
Yes, it is good stuff, even for diesels as the can says!:Bob_Fout said:Some folks (even a guru or two) use seafoam in the tank to dry up water, clean the fuel system, or heck, even fill the fuel filter with it when changing (pre-PDs). People act like it's bad stuff when it's been around a long time and seems to contain the same stuff as other additives (naptha).
DRbillZ said:Uh.......OK. Just wanting to see waht people thought of the product.
sorry if i misunderstood the intent of the thread. the way I read it, you were just trying to stir things up. so i called you on it. I'll let the moderator decide if that is the way it comes across.DRbillZ said:Uh.......OK. Just wanting to see waht people thought of the product. Was trolling for responses, yes, not problems or flames.
Seems you did a bit of trolling yourself.
Agreed, I steered clear as well since it just looked like trolling. This is a topic that seems to spark a bit of debate around heretditom said:sorry if i misunderstood the intent of the thread. the way I read it, you were just trying to stir things up. so i called you on it. I'll let the moderator decide if that is the way it comes across.
suggestion: ask (or state) something specific when you start a thread.
I guess he didn't search.gforce1108 said:Been discussed recently:
http://forums.tdiclub.com/showthread.php?t=223318
search doesn't work for you? I wonder how that could be true...DRbillZ said:Nope. I don't search for much here. It turns up very little ......for me. But thanks for the link. Never read about it here and thought that odd.
You'll notice that the top hits there are his own thread. If you don't change the search parameters to 'relevancy' instead of by date you get a lot of crap. Changing that parameter gives you this:tditom said:search doesn't work for you? I wonder how that could be true...
http://forums.tdiclub.com/search.php?searchid=3109695
