Old May 10th, 2019, 13:35   #1
UncleSpence
TDI(s): 2003 Jetta
Fuel Economy: 38-44mpg
Default Spare Tire Size
I bought a 2012 Jetta TDI recently for a price that I couldn't refuse. $7k with just over 60k on the odometer (6speed manual). Was recently from Michigan on the buyback program. Only issue I've found thus far has been that the original owner took the spare tire and tool kit out before they turned it back into VW. Did find the lug key which was a nice bonus.
It's a bit of a nuisance because anytime you put something in the trunk, there's no support, so it sags and all my groceries and stuff fall in a pile and disform the trunk lining.
I'm assuming by the size of the hole it was a full-size spare. Is that correct? My Mk4 tdi has a full size spare. Is there a year range of jetta spare tires that will fit this? Or does the Mk6 vary from the Mk4 and Mk5?
If you happened to steal yours before the buyback I'm in the market for a tire and kit.
Thank you for your time and infinite wisdom All Knowing Ones.
UncleSpence is offline   Reply With Quote
Old May 12th, 2019, 07:07   #2
scooperhsd
What size tires are on the rest of the wheels ?
If 16 inch -
I found this on amazon
https://www.amazon.com/16X6-5-finish...lkswagen+Jetta
2000 Red NB TDI, 370,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old May 12th, 2019, 07:20   #3
Graham Line
Because I do some long cross-country Interstate drives, my spare is the same tire and wheel as the other four.
Can't remember the size, but it fits perfectly in the spare wheel well of a 2012 TDI Golf two-door. I wasn't enthusiastic about crossing South Dakota with a spare limited to 45 mph.
Too bad you're in Texas. The OE spare just takes up space in my garage. Aren't dealers required to supply a spare?
Graham Line is offline   Reply With Quote
Old May 12th, 2019, 09:05   #4
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Should be a 205/55-16. Just find a local salvage yard that has a VW steel wheel with a tire on it and use it as the spare. That's what I did when I wanted a full size spare instead of the donut that came with our '15 GSW. I have the donut in the garage if you want to make me an offer, but shipping would be $$$.
-George Bernard Shaw
Old May 12th, 2019, 10:55   #5
scooperhsd
Just make sure of
1. the spare is also rated to 91 H like your regular tires.
2. You replace the spare as the tires ages - I had a almost unused fullsize spare on my Beetle - from when it was sold in 2000. I replaced that when I replaced my rear tires and I kept the best for my replacement spare - last summer when I was moving from Raleigh to Kansas City.
You also need to replace the donut spares every so often as well - say every 5 years (maybe less) .
Long time ago - I replaced the bolts that required the special lug key with regular bolts from the VW parts dept. That way, I don't have to worry about finding / keeping track of that PIA part.
Old May 14th, 2019, 15:49   #6
UncleSpence
TDI(s): 2003 Jetta
Thanks for the perspective all, and for the offers of spare tire sales. It will likely be cheaper to either buy the rim and put an older tire on it, or go the salvage yard route and find something compatible.
Old May 15th, 2019, 12:10   #7
Rob Mayercik
Sounds like you got this car at a VW dealer. Have you asked them about this?
Seems to me that a case could be made that a car that came from the factory with a spare tire should not be able to be sold by a dealer without one (call it a safety issue, perhaps?). Technically, then, your car is "missing parts" and I'd think the dealer you bought it from should be making you whole.
Have you spoken to the dealer or VW about this?
2002 Jetta GLS TDI Automatic
Baltic Green/Beige Leather
400K miles as of Dec 2019!
Rob Mayercik is offline   Reply With Quote
Old May 15th, 2019, 12:17   #8
oilhammer's Avatar
Fuel Economy: fantastic
I would ask the selling dealer about it, agreed. Can't hurt.
www.cardocautomotive.com
Old July 20th, 2019, 13:50   #9
UncleSpence
TDI(s): 2003 Jetta
To conclude this thread...
The dealer I bought it from was a small spot, with maybe a dozen cars at the time that I bought it. He was also closing his business as he was not doing very well, which was why I got a respectable deal on the car.
I ended up going to a scrap yard and bought a 16" steal VW/AUDI wheel for $30. I'll likely buy a cheap rubber from a tire place now and then find the jack and wrench kit somewhere else, or keep shopping at scrap yards when I pass them on the highway.
Old July 22nd, 2019, 08:33   #10
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Or you can always try ebay...
Old July 22nd, 2019, 10:06   #11
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
car-part.com has an excellent database to help find that stuff in your area. Should be cheap and easy find.
Spare tire size igiveup VW Passat Family (NMS and B7) TDIs (2012+) 7 September 27th, 2018 21:32
Weight saving: compact spare available to replace full size spare tire? austi012 Upgrades (non TDI Engine related) 96 July 17th, 2014 10:42
Spare tire size av8or VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 5 July 9th, 2012 09:31
Spare tire size tank weasel Ontario 8 July 12th, 2008 19:26
Will A Full Size Tire Fit in a (A3) Spare Tire Well? Ric Woodruff VW MKIV-A4 TDIs (VE and PD) 10 September 4th, 1999 00:41
Page generated in 0.14466 seconds with 13 queries
[Output: 102.34 Kb. compressed to 86.34 Kb. by saving 16.00 Kb. (15.63%)]
