Old May 11th, 2019, 00:22   #1
joshhol
Default GSW buyback with no maintenance history
Iím looking at a GSW TDI with 50K on it, CPO from a dealer. The carfax has a lot of annual state inspections listed and other stuff but no sign of regular maintenance intervals except for the one done by the dealer to prep it for resale.
I know carfax doesnt always get maint reported if it was an indie shop or even DIY. Iím not sure why anyone would do that since first few oil changes should have been free. When dieselgate broke, I know there were people that wouldnt even spring for an oil change until they did a buyback.
Not too worried about the car itself since its a CPO but is there any way to know if the engine is ok other than a compression test?
How involved are those to do on the EA288?
joshhol is offline   Reply With Quote
Old May 11th, 2019, 11:46   #2
Lightflyer1
Lightflyer1's Avatar
Being it is a CPO, if it starts and runs good with no annoying sounds, I wouldn't worry. It has made it this far and you have 2 years to see if anything pops up. I would insist they do the 40k service though before buying it. If it is a DSG this will be $800 +/-.
Old May 12th, 2019, 15:38   #3
06bluebeetletdi
For 2015s vw only covered one oil change. Not all dealers report to carfax, my local dealer does not.
06bluebeetletdi is offline   Reply With Quote
Old May 14th, 2019, 08:48   #4
flargabarg
If it restarts instantly once warmed up and under the oil filler looks clean, I would not worry about it.
flargabarg is offline   Reply With Quote
Old May 14th, 2019, 15:05   #5
andreigbs
TDI(s): N/A
Perhaps owning those older Merc diesels makes you a little concerned about compression Don't worry about that on a modern TDI. You'd be able to tell right away if it was anything other than "normal."
As others have advised, if it starts right up, idles smoothly and makes decent power it's more than likely just fine. Of course, I'd do the oil change and fuel filter change, and if it's got a DSG transmission I'd ask for a discount on the flush service which was likely overlooked. I'd want to be sure I got fresh fluids in there, then motor along knowing you have 2yrs "pretty much everything's covered" CPO warranty and another 8-10yrs or up to 120K miles of the extended emissions warranty which also kinda covers most of the important bits.
In short, if it checks out clean, runs well and has no rusty bits, I'd buy it.
BMW X3d // 55xxx miles // 35 MPG & GLK250 // 121xxx miles // 32 MPG
Jetta TDI // 49xxx miles // 39 MPG - sold
Golf TDI // 45xxx miles // 38 MPG - buyback'ed
Bora TDI // 146xxx miles // 42 MPG - sold
Jetta TDI // 317xxx miles // 44 MPG - sold
andreigbs is offline   Reply With Quote
Old May 21st, 2019, 05:19   #6
joshhol
Wink
Thanks all. Well, the car got snatched up by someone else before I could move. Still on the hunt..
Yeah, the old MBís keep compression on the mind
Old May 22nd, 2019, 06:39   #7
psd1
Fuel Economy: See Fuelly link
Don't sweat the small stuff!
psd1 is offline   Reply With Quote
New (to me) TDI - 2015 GSW SEL (a Buyback) ritsco VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 14 September 21st, 2017 17:34
Maintenance history Tom Brown TDI 101 12 September 30th, 2014 17:47
Low miles Vs. No maintenance history chipmmm TDI 101 7 October 17th, 2013 10:03
Can maintenance history be searched by VIN? Overdraw TDI 101 16 February 28th, 2008 07:23
no maintenece history. what maintenance needed? wnytdi VW MKIV-A4 TDIs (VE and PD) 10 April 14th, 2005 10:56
Page generated in 0.14578 seconds with 13 queries
[Output: 79.09 Kb. compressed to 68.79 Kb. by saving 10.30 Kb. (13.03%)]
