SSRD
Photos:
http://s54.photobucket.com/albums/g83/frogalope/Jetta/
Asking price: $17,500.
Good condition, 59,722 miles on her.
Exterior: Platinum Gray (LD7X)
Interior: Gray Leather (VG)
Extras:
Heated Seats
Keyless Entry
15”Alloy Weels
Fuel economy EPA highway (mpg): 46 and EPA city (mpg): 38
All scheduled service current. Cooling fan replaced 6/06. New clutch 11/07.
2004 Volkswagen Jetta GLS TDI Sedan Performance & Efficiency Standard Features
- Turbo compressor
- 1,896 cc 1.9 liters in-line 4 front engine with 79.5 mm bore, 95.5 mm stroke, 19 compression ratio, overhead cam and two valves per cylinder
- Diesel fuel
- Fuel economy EPA highway (mpg): 46 and EPA city (mpg): 38
- Pump injection fuel system
- 14.5 gallon main diesel fuel tank
- Power: 74 kW , 100 HP SAE @ 4,000 rpm; 177 ft lb , 240 Nm @ 1,800 rpm
2004 Volkswagen Jetta GLS TDI Sedan Handling, Ride & Braking Standard Features
- Four-wheel ABS
- Four disc brakes including two ventilated discs
- Electronic brake distribution
- Electronic traction control via engine management
- Immobilizer
- Fullsize steel rim internal spare wheel
- Strut front suspension independent with stabilizer bar and coil springs , torsion beam rear suspension semi-independent with stabilizer bar and coil springs
2004 Volkswagen Jetta GLS TDI Sedan Exterior & Aerodynamics Standard Features
- Body side molding
- Body color front and rear bumpers
- Chrome/bright trim on side of body and on bumpers
- Coefficient of drag: 0.3
- Day time running lights
- Driver and passenger power heated partial-painted door mirrors
- External dimensions: overall length (inches): 172.3, overall width (inches): 68.3, overall height (inches): 56.7, wheelbase (inches): 98.9, front track (inches): 59.6, rear track (inches): 58.8 and curb to curb turning circle (feet): 35.8
- Complex surface lens halogen bulb headlights
- Metallic paint
- Fixed rear window with defogger
- Glass electric front sunroof
- Tinted glass on cabin
- Weights: curb weight (lbs) 3,003
- Windshield wipers with variable intermittent wipe
2004 Volkswagen Jetta GLS TDI Sedan Interior Standard Features
- 12v power outlet: front and 1 , 12v power outlet: cargo and 1
- Air conditioning
- Roof antenna
- Peripheral anti-theft protection
- Audio anti-theft protection: code
- Monsoon audio system with AM/FM, CD player and cassette
- Cargo area light
- Cargo capacity: all seats in place (cu ft): 13
- Clock
- Full dashboard console , full floor console with covered storage box
- Delayed/fade courtesy lights
- Cruise control
- Front seats and rear seats cup holders fixed
- Door ajar warning
- Door pockets/bins for driver seat and passenger seat
- Floor covering: carpet in load area
- Floor mats
- Driver and passenger front airbag with occupant sensors intelligent
- Bucket driver and passenger seat with height adjustment
- Height adjustable 3-point reel front seat belts on driver seat and passenger seat with pre-tensioners
- Front seat center armrest
- Lockable glove compartment
- Two height adjustable head restraints on front seats , three height adjustable head restraints on rear seats
- Illuminated entry system
- Internal dimensions: front headroom (inches): 37.4, rear headroom (inches): 36.5, front leg room (inches): 41.5, rear leg room (inches): 33.5, front shoulder room (inches): 53.7, rear shoulder room (inches): 52.5 and interior volume (cu ft): 85
- Low fuel level warning
- Low washer fluid level warning
- Remote power locks includes power windows
- Power steering
- Front power windows with two one-touch , rear power windows
- Front and rear reading lights
- 3-point reel rear seat belts on driver side, passenger side and center side
- Three asymmetrical split bench front facing rear seats with zero adjustments
- Rear view mirror
- Remote fuel filler door release
- Remote control remote trunk/hatch release
- Front and rear roof airbag
- Front seat back storage
- Upgraded cloth/velour seat upholstery with additional upgraded cloth/velour
- Seating: five seats
- Front side airbag
- Eight speaker(s)
- Plastic steering wheel with tilt adjustment and telescopic adjustment
- Tachometer
- Illuminated driver and passenger vanity mirror
- Ventilation system with recirculation setting and micro filter
Extras:
Heated Seats
Keyless Entry
15”Alloy Weels
- Turbo compressor
- Diesel fuel
- Four-wheel ABS
- Immobilizer
- Body side molding
- Metallic paint
- Air conditioning
- Roof antenna
- Cargo area light
- Clock
- Cruise control
- Door ajar warning
- Floor mats
- Power steering
- Rear view mirror
- Front side airbag
- Eight speaker(s)
- Tachometer
