BigTurboAlh
My alh ranger gets dead peddle every time I start it then it’s fine I have pin 20 and pin 44 grounded I read on here those are the 2 brake sensors but it still does it
Are you running a VSS? That really sounds like a missing VSS symptom as the engine doesn't know that you are moving as opposed to just revving and it will stumble once and then figure out that it's missing and then has no issues.MY Alh Jeep does something strange at times. If I take off slow the pedal will cut out for a second. If I let off and get back on it it seems fine. It doesn't do it every time. I will have to check the pins listed. Is pin number 32 a common cause of this symptom?
