veedabowlu
I'm curious to know, if I can swap a 1998 AHU engine in a MK1 OR MK2, WITHOUT swapping instrument clusters... I did do a MK1 1.8t gas swap a few years ago and kept the stock instrument cluster. I used a digital to analog converter to run only the mk1 tachometer. I used an 02J with a mechanical speedo cable. coolant gauge ran fine with mk4 sensor, fuel gauge was left stock and used stock sender...
What other signals, night i be missing (not thinkng of?)
