Here are the codes
Friday,29,November,2019,21:48:17:09494
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
Address 01: Engine Labels: 038-906-012-AGR.CLB
Control Module Part Number: 038 906 012 FF
Component and/or Version: 1,9l R4 EDC G000SG 4104
Software Coding: 00002
Work Shop Code: WSC 00066
VCID: 59EF8EE2000B23AFEE9-4B5C
5 Faults Found:
17068 - Glow Plug Control Module (J179)
P0684 - 35-10 - Implausible Signal - Intermittent
16502 - Engine Coolant Temp. Sensor (G62)
P0118 - 35-00 - Signal too High
16491 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0107 - 35-10 - Signal too Low - Intermittent
17569 - Manifold Temp Sensor (G72)
P1161 - 35-10 - Open or Short to Plus - Intermittent
17656 - Start of Injection Timing Regulation
P1248 - 35-10 - Control Deviation - Intermittent
Readiness: 1 5 0 0 1
Address 01: DTCs cleared
Fault Codes have been Erased
8 Faults Found:
Readiness: 1 4 1 1 1
