I had used the wrong wire for my 5V feed to the VSS sender. Once I had the correct wire the speedo worked fine.
Adding a digital Dakota box to take the crank signal and outputting sort of a cam signal the tach also now works.
A pretty good weekend and the best part was the maiden voyage. :>)
We just did a 3hr family run and its was pretty good. A few small items to fix.
Drivers seat is broken so I think some WJ seats are in my future.
Power windows only work from the drivers panel.
LOTS of black smoke when you stomp on it so I need to look into that. The tune may be a bit too aggressive for my use.
LOTS of power!
Cruises at 60 mph at about 1500RPM in 5th. I found I ran in 4th quite a bit which brought the RPM up to about 2000 which worked better in hilly areas which is most of our area.
It ran nice and cool the whole trip and the electric fans did not come on once.
A pretty good shakedown trip.
Did I mention LOTS of power!
