durdy1
Going to change out tranny fluid to gm synchromesh. I have been searching and trying to find which version would be better the regular or the friction modifier. Any advice would help. Thanks.
sorry but this is incorrect...pennzoil snycrhomesh is designed for transmissions and transaxles as per pennzoils website... our cars use transaxles....a differential is just another set of gears not unlike the other gears in the transmission.... I've had very good luck with synchromesh where the OEM fluids (g050, g070) did nothing or made the situation worse!!I have read some good things on these forums about sycromesh - but have also read syncromesh is designed strictly for transmissions, whereas in TDI's the transmissions share the oil with the differential. So, the oil has to serve different needs. What works well for the transmission may muff up the differential, and vice-versa.
I've heard this about amsoil trans oil....try the pennzoil product it's the smoothest shifting when compared to any of the OEM fluids or lubrimoly ....I personally have not tried redline but I've heard it's also "notchy"I have used amsoil in the tranny. And it shifts notchy 1-2. It dosent grind yet. I have 144000 miles on now. Its been notchy for 20, 000. Didn't know if friction modifier would add better protection on they syncros.
