Q5 Intake Upgrade
Pittdawg
Los Angeles
2014 Audi Q5 TDI
The above is the only prefabbed intake pipe upgrade I have been able to locate for the Q5 3.0 TDI. My only issue is their statement that "This silicone removes the DPF Pressure Sensor Bracket" which the picture confirms. Not sure why you would do that unless going for a complete DPF delete but anyways, what are your thoughts on figuring out a way to mount the OEM bracket onto this silicone hose? Anyone done that before?
PhunkFX
Hudson Valley, NY
2014 Audi Q5 TDI S-Line, 2005.5 Jetta TDI (BRM) 6MT (02Q)
Do you have a link for this pipe?
As far as modification, I would just zip tie it up to anything remotely close, or under, so it's less visible.
PhunkFX
Hudson Valley, NY
Thank you! Notice any difference in throttle response with this, over the stock pipe?
