keith102
205/65/16 (26.5" dia) in General Altimax RT does rub in aggressive turns on a 00 TDI Jetta with 155K miles on stk worn suspension
They show up for me...maybe you need to be logged in as a member?mr.mindless said:am I blind? where are your pictures at NB.org? you link to a page in the gallery section but there are no photos?
Some of the commercial tire websites have calculators for this. I think http://www.tirerack.com and http://www.discounttiredirect.com both have this function buried in the options somewhere...Fairbanks Jetta said:If I could run the 215/75/15's how much taller are these.
Try this one -Fairbanks Jetta said:If I could run the 215/75/15's how much taller are these.
Just tried some 225/75/15s
they rub HARD on the firewall when you turn
gonna try some 205/75s next, pretty sure I've got some in the back yard under about 2' of snow
nope, that'd make it worseGet some wheel spacers, move 'em out 20mm, increase the offset.
Odometer's running 8% slow with the VSS I cobbled together to run an 0a6 transmission on a car with a non-ABS based VSS.Taller tires are completely the wrong approach. The amount of lift is minimal with taller tires, however it will effect your final drive ratio/speedometer in a negative way. If you want lifted do it at the springs/struts. Seriously, don't do downgrades to your car by putting wrong diameter tires on your car.
