deecee
OK LAST CHANCE TO GRAB SOME GOODIES!!!
I am moving house and no longer have VW's, so all this stuff needs to go. I will probably toss/scrap if no one buys it and i'd hate to do that, so make offer if you think too expensive.
B4 tdi intercooler pipework - $50 shipped
https://asheville.craigslist.org/pts/d/ridgecrest-b4-tdi-intercooler-pipes/6766588815.html
20mm Wheel spacers $20 shipped
https://asheville.craigslist.org/wto/d/ridgecrest-20mm-500x100-wheel-spacers/6766585908.html
Mk4 GLI rear seats - $80 shipped ( As long as shipping is less than $80!!, cheaper if collected!!)
https://asheville.craigslist.org/pts/d/ridgecrest-vw-mk4-gli-rear-seats/6766590554.html
Fuel injectors, not sure if B4 or Mk4 but ideal to use as send ins if you are upgrading nozzles, I bought them for that purpose and never used them so I can't tell you the exact history of them. Comes with hard fuel lines, one of the injectors has had the nozzle loosened so selling as cores $60 shipped. They have square connector.
https://asheville.craigslist.org/pts/d/ridgecrest-mk3-4-vw-tdi-fuel-injectors/6789360551.html
ALH hard coolant line from a manual engine.- $20 shipped.
This is ideal if you did a 5 speed swap or engine swap.
https://asheville.craigslist.org/pts/d/ridgecrest-vw-tdi-alh-5-speed-hard/6789365956.html
Mk 4 Golf trunk lid/glass dark blue - $30, not shipping!
https://asheville.craigslist.org/pts/d/ridgecrest-mk-4-vw-golf-trunk-lid/6789369115.html
Mk4 Golf tdi 2 door door card inserts CLEANED!! - $25 shipped
Cant remember if front or rear, but either way yours are probably sagging and these are fully cleaned up and ready to re upholster.
https://asheville.craigslist.org/pts/d/ridgecrest-mk4-vw-golf-2-door-door/6789375512.html
B4 VR6 Air filter/box and MAF - $30 shipped
Mk4 Intercooler- $40 shipped.
I believe this is from a beetle but could be wrong? pipe enters at an angle and the sensor is built in to the intercooler rather than the pipework above.
B4 Lower Control arms- $45 shipped
Ideal if you are replacing bushings and what not in yours. having these to get ready could keep your downtime down.
Mk4 ALH Aluminium accessory bracket from engine block- $80 shipped.
This is the one the alternator and what not connects to. If you can collect i will sell much cheaper.
B4 bits - $10 shipped
Fuel temp sensor, valve for recirc flap i believe, clip from clutch slave/pedal I kept as spare as when it broke I was stranded, other valve I forget name of and some bushings I am sure are for the LCA's
ALH one time use timing bolt kits x2 - not sure if these are complete or not but I can text photo. Looks like most are there. - $10 shipped
ALH timing belt cover? - $30 shipped
Mk4 Golf/Jetta Parking brake cables, brand new $20 shipped
Send me a number and I will text pics. It's in good condition.
ALH intercooler pipe elbow, the one at the top of engine before the intake. - $20 shipped
GLI rear door handle brushed aluminum - $10 shipped
Injector Hold down Clamps, I think I have 10 of them with the bolts. $25 Shipped
Please send any questions or picture requests.
Ill be dumping most of this VERY SOON if not sold, which would be terrible waste, so get it while you can.
