9Rockr
Had some oil leaking issues so I took it in and after getting the valve cover gasket replaced, the shop said the EGR seals are also leaking. As well as the rear main
My question is are the only seals on the EGR the valve seal and small seal? And if so where on the EGR are they and are they easily replaced?
https://www.idparts.com/seal-small-bewbhw-n90062702-p-2027.html
https://www.idparts.com/valve-seal-alhbrmbhw-n90521604-p-566.html
Shop quoted $107 to replace the EGR seals. I know I can pull the EGR off myself and if its only these 2 seals then I can hopefully save $100.
