Old June 23rd, 2013, 12:23   #1
augie dog
TDI(s): 1996 Passat
Default Help Identify Wire Connection!
I posted this in my starter post but no one responded so I will repost. While I was removing my starter there are three separate plug connections located on top of starter as part of the harness. The connection I am inquiring about is a two wire plug going to a round black solenoid looking component adjacent to the clutch master cylinder. I need to repair this connection because the wire is held on by only a couple of wire strands. The plug needs to be cut off and a new plug soldered on. Can anyone shed some light on this and let me know where I can get a replacement / repair plug. If you need photo's I will try and post them but I hope I described as best as I could where it is located.
augie dog is offline   Reply With Quote
Compressor Wire connection replacement salsaenz VW MKV-A5 Golf/Jettas 11 April 15th, 2013 11:52
how to identify turn signal wire? bruca003 VW MKIV-A4 TDIs (VE and PD) 2 September 18th, 2012 16:05
Immobilizer connector (2 pin) to tumbler - Wire frayed at connection fabed23 VW MKIV-A4 TDIs (VE and PD) 3 April 12th, 2012 20:53
2010 Sedan, Help Identify this wire corvettecrazy VW MKV-A5 Golf/Jettas 16 March 8th, 2011 16:37
Mystery electrical connection-help identify DwightC TDI 101 2 May 20th, 2008 21:16
Page generated in 0.12088 seconds with 11 queries
[Output: 46.89 Kb. compressed to 44.21 Kb. by saving 2.68 Kb. (5.71%)]
