what size triple square bit for alternator pulley?
matteas
N. New Mexico
15' tdi GSW
I'm going to replace the alternator pulley on my 98 TDI and am at a loss as to what size triple square bit I should use? Thanks in advance.
Matteas
Matt-98AHU
Gresham, OR
2001 Golf TDI, 2005 Passat wagon, 2004 Touareg V10.
There's really only 4 triple square sizes I ever see used (I havn't even seen any other sizes made from major tool makers). But I have a '98 myself. When I get to work tommorow I'll try to remember to size it up and see what works.
MOGolf
underneath something
2001 Golf GLS TDI Reflex silver, rough road suspension and steel skid plate, 2004 Passat Variant, Candy White, rough road suspension and geared balanced shaft module, and much, much more. 2016 LR RR HSE TD6, 2019 Jaguar I-PACE
A set of 8 sizes: http://www.thetoolwarehouse.net/shop/VIM-XZN100.html
www.metalnerd.com sells the serrated bit you need to hold the pulley for removal and installation, along with the appropriate size long bit you'd need for the alternator. See this page (scroll down): http://shop.metalnerd.com/index.cgi?code=3&cat=5
(says sold out, at the time of this posting)
paramedick
TDIClub Enthusiast, Vendor
Versailles, Kentucky
2015 Audi Q5 TDI
matteas
N. New Mexico
15' tdi GSW
I had seen metalnerds tools but was interested in just the 12 point driver, however I can't figure out what size he uses. I had hoped to find the tool locally. Anyhow I may end up buying a set.
matteas
N. New Mexico
15' tdi GSW
Stealth TdI thanks, I saw your thread, it inspired me to remove the pulley without removing the alternator. You saved me a couple of hours worth of work!
