BuzzKen
Vendor , w/Business number
Anybody got any ideas on what max safe boost for the turbo would be for a GTB2260VK on a 3.0TDI?
Because it probably flows more than an 8v 1.9l. You need to know flow to know where your motor will sit in the compressor efficiency map.Why can't the same turbo run the same boost on a higher displacement engine? That's what I am wondering (and I am no mechanic so genuinely interested to know)
If you taper boost appropriately is it really that hard on the turbo?1.8bar is still safeish. It will not explode but the expecter life of the turbo is not going to like it.
And you can burn all the fuel you get from the pumps on certain 176kw modes even with stock turbo...Good car ruined by CP4 pump.
