fastcar4re
My 2005 Passat TDI has an oil leak and I will not be repairing it myself. I had the valve cover gasket replaced, and will have the "corners" of that checked, but my question is: So that I have a general idea of what is likely to be the issue, can anyone give me the "top three" or so places from which this BHW is likely to leak oil? I have 133,000 miles on it and it has a Diesel Geek skid plate on it, which I can't easily remove myself. In 3,000 miles I have put in 1.5 quarts, and before the leak it hardly used any oil. The spots on the ground are large. Top 3 anyone? ... and if anyone suggests the "tandem pump" can you tell me what that item does and what leaks on it? As always, thanks!! I surely appreciate it.
