Yblocker
As part of the effort to bring the '97 Passat back from the brink, I've got the intake system pretty well squared away. I also replaced the N75 solenoid, replaced the fuel filter, primed it with Diesel Kleen (silver bottle) and eliminated that Mr. Gasket fuel pump that was between the filter and the IP. I have not started the car yet.
Ive been reading about replacing the vacuum hoses, and it seems like a good idea, but wanted to run my idea past you guys regarding the infamous little hose in the ECU. Instead of pulling it apart to check, why not just apply some vacuum to the hose coming out of the unit. If it holds, then maybe one is better of leaving that one alone since the ECU is easily damaged. The rest of the lines can easily be replaced....
